I'm looking to dye my Noctua fans black and red. where can i buy some dye? do i just buy food coloring?
CPU AMD FX 8350 @5GHz. Motherboard Asus Crosshair V Formula Z. RAM 8GB G.Skill Sniper. GPU Reference Sapphire Radeon R9 290X. Case Fractal Design Define XL R2. Storage Seagate Barracuda 1TB HDD and 120GB Kingston HyperX 3K. PSU XFX 850BEFX Pro 850W 80+ Gold. Cooler XSPC RayStorm
https://linustechtips.com/topic/132530-dye-for-fans/
You will need a stronger dye than food coloring. You can find a tutorial here. http://forum.overclock3d.net/showthread.php?t=35185
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/132530-dye-for-fans/#findComment-1764043
I tried that guide ver batim. It didn't work. Then I tried doubling everything. Cooking time, ingredients, everything. Still didn't work.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/132530-dye-for-fans/#findComment-1764082
