Home made PWM adapter?
samuel
Hello guys. Found this:
ak-cbfa03-45-d8de7d38ed170fc43e4dba4b508
And I want to make one for myself. I don't wanna buy one no matter how cheap it would be. All I have is a 4 pin fan connector, cables , electrical tape and guts. Can anyone post a diagram or something so that I won't short out my motherboard? It's a fan splitter with PWM control on the motherboard and PSU powered at the same time.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
Yellow = 12v
Black1 = gnd
Black2 = gnd
Red = 5v
If you want 5v, wire the fan connectors to the red molex wire and either black one.
If you want 12v, wire the fan connectors to the yellow molex wire and either black one.
If you want 7v, wire the fan connectors to the red molex wire and the yellow one.
It'll be really hard to make proper disconnect-able fan connecters without real plugs, but you could do it. I've made heaps of 7v adapter using fan cable extensions that I've cut up. It's very hard to damage your PSU doing this if you have at least very basic circuit knowledge.
If you don't have any fan connectors, I suggest you just buy some adapters. They're like $5 for molex > 3x adapters.
Laptop Lenovo Thinkpad X220 - CPU: i5 2420m - RAM: 8gb - SSD: Samsung 830 - IPS screen Peripherals Monitor: Dell U2713HM - KB: Ducky shine w/PBT (MX Blue) - Mouse: Corsair M60
Audio Beyerdynamic DT990pro headphones - Audioengine D1 DAC/AMP - Swan D1080-IV speakers
sticky this. wait a minute this is not the best place! so mods please move accordingly and sticky please
AMD FX 8350 | 2X XFX RADEON HD7850 | ASUS SABERTOOTH R2.0 | NZXT GUARDIAN 921RB | KINGSTON HYPER-X 2X8GB
Yellow = 12v
Black1 = gnd
Black2 = gnd
Red = 5v
Thanks for response but I already know this. I was reffering to PWM Software control within Speedfan for like 8 fans in one  4 pin connector.
That may fry your motherboard fan header, or simply not work. And using molex at the same time for aditional power won't work, because the Pulse Width Modulation signal used to control the fans is from the motherboard, and a molex can't do that.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
Nope, sorry man but I believe you're incorrect!
I don't want to sound like a know-it-all, I just try to avoid misinforming people, and if you can prove me wrong I will not be offended :P
Just to make some things clear for peaople in the future reading this thread.
As long as you get the wiring correct, the way you plan to do this is the correct way, and you will NOT fry any fan headers on your mobo. That's what the molex power connector is there for, it's feeding power to the fans, while all the cable to the fan header does is to provide the pwn signal to the fan, and the tach signal to the mobo.
The PWM signal is only a voltage signal (it has very little amperage), which is why it can safely be splitted.  =)
Have you gotten anywhere with your problem?
The only problem that you may encounter with the PWM splitting is that the RPM reading for the fans may go off the charts, not sure how this affects speedfans ability to control them, since I haven't been using speedfan since the good old 3-pin fan days :P
Have you tried your cable at all, or did you get spooked by previous comments on fried fan headers?
Here's a video on controlling fan speeds with speedfan, if you haven't seen it already:
https://www.youtube.com/watch?v=8VjdQStihsE
Just to clarify, since you only have one PWN signal, from each PWM header, you can't control different fans connected to a single fan header individually.
