Hi,
It just occurred to me that it'd be pretty cool to have side panel windows that are smart glass and therefore you could adjust the panel's opaqueness. Have you ever seen cases with smart glass side panels? How about after market smart glass side panels?
i7 3770 | Asus GTX670-DC2-2GD5 | Kingston HyperX Blu 16 GB | Samsung 850 Evo 1TB
Fractal Design Define R4 | Nexus RX-8500 850W | Asus P8Z68-V-PRO/GEN3 | 2 x Asus 24.1" PA248Q
“An expert is a man who has made all the mistakes which can be made, in a narrow field.” – Niels Bohr
https://linustechtips.com/topic/132482-smart-glass-side-panel/
It would definitely be cool and would cost as much as making a custom one (one kidney).
https://linustechtips.com/topic/132482-smart-glass-side-panel/#findComment-1763390
If you can afford it, why not. But it sounds a bit pointless...
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/132482-smart-glass-side-panel/#findComment-1763391
You would have to install one yourself. This sounds awesome though. You could also use LEDs to brighten it up instead.
Yeah, I thought as much. I have never seen smart glass on a case.
https://linustechtips.com/topic/132482-smart-glass-side-panel/#findComment-1763396
I've heard that the price could me moving up to One Kidney and an Eyeball soon... Sign of the times I guess.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/132482-smart-glass-side-panel/#findComment-1763555
