Hello i have a problem with my dual monitor setup. I have a 24 inch monitor and a 40 inch tv (both 1080x1920p) but windows sees them as the same size. This happened to me while using a 21.5 inch monitor and the same 24 inch monitor. I don't think it's my gpu cause both my old HD 6850 and my new 1650 have this problem. So i think it might be because the monitors are old
Benq BL2410 (secondary monitor)
KDL-40R455B (main TV)
thanks for the help
https://linustechtips.com/topic/1324327-wallpaper-line-up-problem/
What exactly is the problem here?
From Windows' perspective they are the same size because they have the same number of pixels. There's nothing you can do about this.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
48 minutes ago, Superrockboy57 said:
the problem is that the wallpaper doesn't line up
I'm still not quite sure what you mean - it's very difficult to see that when you only provide a screenshot of one screen!
Can you take a screenshot or photo including both screens? I believe if you activate the snip tool with Win+Shift+S then you can drag across multiple monitors.
pythonmegapixel
