CPU temps fluctuating... Help, I think?
Go to solution Solved by LogicalDrm,
2 hours ago, _quarterthor said:
So it is just a AMD thing where they fluctuate while idling? In game it doesn't really get above the 60's, so I guess when it counts it's keeping it cool as well.
No, its computer thing. Temps are reaction to electricity driven through silicon. Cooler/fans will spin up to move produced heat away. More load, more heat, higher fan speeds. Also idle is not truly idle. You will always have background processes.
With Ryzen, this is tad more visible than what it used to be, thanks to PBO constantly adjusting settings. But its still how computers normally operate.
So I recently installed a Hyper Evo 212 RGB to my Ryzen 5 3600 and the baseline idle temps as well as the temperature when I'm using it are down, but my idle temps are fluctuating from about 30c up to 45c. Is this normal? I have a RX 580 GPU (I want to upgrade it, but we all know the problem with that now) and 6 Corsair 120mm fans creating a neutral zone inside my PC. So, are my fluctuating temperatures normal? Should I worry? Thanks, guys!
RIG! CPU: Ryzen 5 3600 | Motherboard: ASRock B550 Pro | Ram: Corsair Vengeance RGB Pro 16GB DDR4 3200 | GPU: Radeon RX 580 4GB | PSU: Corsair CX750 | Case: Corsair Carbide Delta RGB | Cooler: Master Cooler Hyper Evo 212 RGB | HDD: WD 2.5 2TB | SSD: Kingston A400 250 GB | Monitor#1: Dell 27" 60Hz | Monitor#2: Sceptre 27" 60Hz
https://linustechtips.com/topic/1323800-cpu-temps-fluctuating-help-i-think/
Just now, Pikatchu said:
Normal Temps.
Thanks!
Probably just the fan curve. You might want to adjust it just so the fans don't have to constantly ramp up and down, but the temps themselves are nothing to worry about.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
I have my fans set at 100 while I was testing the temps so the fan curve wasn't a variable, for the most part at idle they will go from about 33c to about 40c. Though they will dip and raise a few more degrees from time to time. I just didn't know if fluctuation was normal or if I should worry about it.
My R7 5800x dose the same on a 360mm AIO but in games it runs in the 60s and benches in the 70s.
My Intel CPUs have a more constant idle but they and the R7 run cool when it counts.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks so much! That's what I am starting to gather, that the temps are fine and it is just how PCs operate and that it is just a little more noticeable with my Ryzen.
