4 minutes ago, Jk-0770 said:
I was wondering if this is a good PC. This will be my first ever build, please let me know! (Only part I don't want to change is the case)
PC Part Picker Parts List
its blank
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14625763
Budget (including currency): $2700
Country: USA
Games, programs or workloads that it will be used for: Rust, Minecraft, Fall Guys, Rainbow Six Siege.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm planning on making this after new parts drop for PC (want to get parts for cheaper). This will be my first PC so any suggestions help!
This is a current list I have, I was wondering if anyone had suggestions. Only thing I don't want to change is 680X Case.
PC Part Picker List
Thanks!
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628395
Honestly this is totally fine for 2021. The only thing i would consider is a different GPU if you can find one. For $850 it's really hard to justify a RX 5500 XT. However It will run those listed games with out any problems.
one idea is get the i5-10600K for $20 more and run onboard graphics while you try to get a card.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628430
Swap out the monitor for this one.
https://www.amazon.com/gp/product/B08JWCHR5N?tag=rtings-mn-r-20&ie=UTF8
Linked is an RTings comparision between it and the one you selected.
https://www.rtings.com/monitor/tools/compare/msi-optix-mag271cqr-vs-gigabyte-m27q/928/19668?usage=9091&threshold=0.1
I would then put that saved $ towards a high end wireless mouse. I like Logi and Razer's recent mice, but it's all personal preference.
The Corsair fans aren't especially good in terms of acoustics or performance, especially for the price. Look up a bunch of graphs and find a better/cheaper set and maybe put those savings towards a second monitor. (Try to get a secondary monitor that is also 1440p to avoid Windows scaling issues)
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628438
Country: USA
PC Part Picker List
Thanks!
Troll build?
If not, here's my recommendation:
(Your Mobo, case, and GPU are extremely overpriced). Not going to comment on your accessories but I'd change out the keeb, monitor, and mouse most likely
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628439
2 minutes ago, Brok3n But who cares? said:
Troll build?
You can't get a card like that for that money. Your comments are valid but well you have to be reasonable too and let op buy their system this year still.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628456
Brok3n's parts list is great, obviously the GPU's aren't in stock, but a used 10X0 card would be better than a new 5500 XT. Pair that with everything else in his list, grab the monitor I linked, and you should be all set. R6 especially loves Ryzen. Far better frametimes in game.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628459
Camping bestbuy you can do a whole lot. Even just having a youtube tab open with a stock bot can help you get a card. The other day I basically checked bestbuy at random and nearly got a card, I didn't because I was late to the party. If you use say the fixit fixit fixit yt channel, you can get notified and get in queue for a bestbuy drop within 30 seconds even if you're not camping. If you know how to get a card and use the right resources it's not very hard.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628468
Still basically based on luck. So op would first need to get a gpu before anything else as well the whole system won't work without anyways.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628478
You tip the scales as much as you can in your favor. Imo some things in life are worth waiting for, ampere cards included. If OP doesn't share my ideology they're welcome to purchase a different GPU.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14628507
Budget (including currency): 15K
Country: USA
Games, programs or workloads that it will be used for: Rainbow Six Siege, GTA, Red Dead, Driver San Francisco
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  Buying soon, best possible set up no set parameters for size. All peripherals included in build. Please make a set up because I don't even know how to get started with this budget.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14633221
Okay. I just made a 12.2k intel and nvidia build. Hopefully it's got components that u were looking for. I know a lot of people would've gone with an AMD Threadripper put I'm personally an Intel guy. Everything should be able to fit in the case since it is a full atx case. Also, you would still have to get an SLI connection to connect the 2 GPUs but that doesn't seem to be available on PC Part Picker. I would recommend using NVLink for this. Here is the build info from PC Part Picker:
PCPartPicker Part List
Type Item Price
CPU Intel Core i9-10980XE 3 GHz 18-Core Processor $992.98 @ Newegg
CPU Cooler NZXT Kraken Z73 73.11 CFM Liquid CPU Cooler $270.00 @ Amazon
Thermal Compound Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste $6.65 @ Amazon
Motherboard Asus ROG Strix X299-E Gaming II ATX LGA2066 Motherboard $499.99 @ ASUS
Memory G.Skill Ripjaws V 128 GB (4 x 32 GB) DDR4-4000 CL18 Memory $819.99 @ Newegg
Storage Sabrent Rocket 4 Plus 4 TB M.2-2280 NVME Solid State Drive $801.85 @ Amazon
Video Card MSI GeForce RTX 3090 24 GB GAMING X TRIO Video Card (2-Way SLI) $3299.99 @ Monoprice
Case Asus ROG Strix Helios ATX Full Tower Case $297.99 @ Amazon
Power Supply Corsair HX Platinum 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply $585.50 @ Amazon
Operating System Microsoft Windows 10 Pro OEM 64-bit $139.88 @ Other World Computing
Case Fan Noctua A14 PWM chromax.black.swap 82.52 CFM 140 mm Fan $24.90 @ Amazon
Monitor Samsung Odyssey G7 27.0" 2560x1440 240 Hz Monitor $699.99 @ B&H
Keyboard Corsair K100 RGB Wired Gaming Keyboard $184.99 @ Best Buy
Mouse Logitech G502 LIGHTSPEED Wireless Optical Mouse $114.88 @ Amazon
Headphones Corsair Virtuoso RGB 7.1 Channel Headset $179.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $12244.46
  Generated by PCPartPicker 2021-04-09 23:03 EDT-0400
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14633277
Country: USA
Your stated use for this doesn't equal the budget you gave. A simple $800-$1500 build would perform the function you are asking for.
Are you truly looking to spend this much on a build? or setting this budget as you dont know what to expect for pricing?
Also, you have 2 other active topics asking for help with a new build.
We do not allow topics on Fantasy builds. We also don't allow multiple topics of discussion a the same new build, please keep topics to one thread.
Please choose one topic to keep active and I will lock the others.
Edited by SansVarnic
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14633642
Budget (including currency): $2,200
Country: USA
Games, programs or workloads that it will be used for: Rainbow Six Siege, GTA, Red Dead, Microsoft Flight Sim
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am rather new to PC and don't know a whole lot, can you tell me what you think of my build/recommend changes. Thanks!
PC Part Picker Part List
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14635415
The power supply seems a little generic, I think I would go with a FOCUS GX850, or Prime I'm not sure what the difference is. Either way, 650 - 850 watts is a great choice. For a cooler, I don't like the looks of those style of coolers, but also I think the cooler used PCPP's enthusiast AMD build performs better. Your choice, but I would go with the cooler PCPP chose. On the CPU most people say the 3600 is better than the one you have, because of it's best value. On this one actually I wouldn't care, but I might actually go with a 3700X. For the motherboard, you might already have the best that fits in your budget, but my filter would be: known brands, good reviews, still in budget (obviously), and has a bunch of upgrade compatibility features. Now, last one I believe. I can't look for it because I'm stuck on mobile rn, and I don't really do a lot of things on mobile. But I would look for a monitor from Asus (probably TUF), 1440p 144Hz, IPS panel type, your choice of size. Bound to be one out there.
Lemme know if this helps.
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14635485
This was pretty helpful, Thanks!
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14635501
-= All topics Merged =-
In the future when a moderator asks you a question, please respond to it.
Multiple topics on the same subject about the same build is not allowed.
We are here to help but please don't spam the forum till you find the answer of your liking. This is not reddit.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14636074
Ok, sorry I didnt know how to respond at the time
https://linustechtips.com/topic/1323530-ratehelp-with-pc-build/#findComment-14636281
