System shuts down randomly
14 hours ago, smore09 said:I have been running without problems for the last few days on the original config.
It restarted again, so i had an idea. I swapped the motherboards and checked the socket. I found some bent pins and one broken pinhead.
According to the 1150 intel spreadsheet the broken one is G10 (PEG_RXN5) which is used for PCI Express Receive Differental Pair. (it would make sense)
The other 2 pins that are a bit weird are M17 (VCC->Ground) and B4 (VSS->Ground).
I hope i read the spreadsheet correctly, the pins are so small.
So i guess the broken pin is what caused the problem, but it is still not 100% though. I'm gonna run this system for a while and report back.
I don't know if these pins still in contact with the cpu, so it is just a wild guess but seems logical to me. The bitlocker shutdown problem is also gone, it does not enter a restart loop and shuts down corretly.
