Budget (including currency): not above 4k
Country: australia
Games, programs or workloads that it will be used for: Minecraft, csgo, 3d modelling, editing,
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): i need suggestions, idk if my build is good enough, give me what to upgrade.
PCPartPicker Part List: https://au.pcpartpicker.com/list/kLFXt8
CPU: Intel Core i7-10700KF 3.8 GHz 8-Core Processor  ($449.00)
CPU Cooler: NZXT Kraken X63 98.17 CFM Liquid CPU Cooler  ($249.00)
Motherboard: Asus PRIME Z490-A ATX LGA1200 Motherboard  ($339.00)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($169.00)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive  ($89.00)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($63.00)
Video Card: Asus GeForce RTX 3060 12 GB TUF GAMING OC Video Card  ($999.00)
Case: NZXT H510 Elite ATX Mid Tower Case  ($279.00)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($189.00)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($169.00)
Total: $2994.00
Generated by PCPartPicker 2021-04-07 21:41 AEST+1000
Edited by antonioisadude69
i forgot to add some stuff
https://linustechtips.com/topic/1323068-my-first-pc-build-pls-help/
you don't need this for minecraft and csgo
