So for the past 2ish weeks I’ve developed a  problem where during or after closing a game, my PC crashes BSOD and says WHEA_UNCORRECTABLE_ERROR. I don’t know what I’m doing wrong and have tried a couple solutions of the following. Any suggestions is helpful! I don’t know what developed this error as I was never persistent in making changes in my computer since it always worked great. I don’t overclock either and leave everything be in the BIOS. (especially since I just updated the BIOS and haven’t made any changes) I don’t think it’s overheating either because it’s always ran perfectly fine where it stands for air flow hot or cold.
i have tried:
-Updating the BIOS
-Updating the GPU’s Drivers
-Ran Cinebench R20 for single and multi core
-Ran Haven Benchmark
-Disconnected the power for a couple of hours
PC:
-Ryzen 5 5600x
-Nvidia RTX 3080
-(8x2) 16GB 3000MHz GeIL ram
-1200W Corsair PSU
-2TB Samsung 860 EVO SSD
-1TB Seagate Barricuda SSD
-B450 Carbon Pro Gaming AC
https://linustechtips.com/topic/1322990-help-with-whea_uncorrectable_error/
i have tried:
-Updating the BIOS
PC:
-Ryzen 5 5600x
-Nvidia RTX 3080
-1200W Corsair PSU
  1. Step 1: Run CHKDSK. ... ...
  2. Step 2: Reset System Overclocking. ...
  3. Step 3: Reset Your BIOS/UEFI Settings. ...
  4. Step 4: Update Your BIOS/UEFI Settings. ...
  5. Step 5: Check Your Drivers. ...
  6. Step 6: Check Your RAM Using MemTest86.
  7. Step 7: Reset Windows 10 (Last Resort)
hi, im renata bliss and am ur freestyle dance teacher
i have tried:
-Updating the BIOS
PC:
-Ryzen 5 5600x
-Nvidia RTX 3080
-1200W Corsair PSU
Also check if your CPU is properly seated into your socket.
This is a long standing, well known Ryzen bug,  cause unknown...
Though there are a couple of fixes you can try.*
Also lots on reddit, r/amd and otherwise (though I don't have the links right now)
Basically it's a pcie  / chipset driver  / general poor driver support compared to a not further named "blue" company issue.
Although they have this bug too just much less frequently.
*read this
https://forums.guru3d.com/threads/beware-of-whea-errors-on-x570-platform-pcie-data-coruption.427789/
And no, the info this is only 570 is obviously incorrect,  it can happen on any ryzen board.
(I get those too, I'm just lucky and it's not crashing)
-Scott Manley, 2021
