Budget (including currency): 500-800
Country: Lithuania
Games, programs or workloads that it will be used for: Games like CSGO, PUBG and more fps games that require good pc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I already have a pc, but i want to upgrade it and i want to know, what should i start with. My pc Spec: Processor Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz, 2904 Mhz, 6 Core(s), 6 Logical Processor(s). 16 GB RAM,
and yeah, I don't know what else to include. Now I just want to start upgrading my Pc bit by bit so it becomes more powerfull, and i need help :D And I will put my pc case picture here.
https://linustechtips.com/topic/1322191-need-help-with-pc-upgrading/
1 minute ago, Rubah said:
Well I don't really know 😕 I just want to upgrade it so my pc doesnt become old and could run good games 😄
Ok,
Well let's break this down:
Getting a new GPU, in the current market, is impossible unless you like getting ripped off.
RAM is fine
RAM slots are only 2, so that's maxed out
What is your storage like?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Just now, Radium_Angel said:
Ok,
RAM is fine
Storage is  240 in the main Disk C: . And I have an SSD with 450GB  . Idk if the number are right, i just quickly looked on my pc
Just now, Rubah said:
Storage is  240 in the main Disk 😄 . And I have an SSD with 450GB  . Idk if the number are right, i just quickly looked on my pc
So both are solid state?
What do you use for backing up your important data?
Well I just use these 2, Main one for important data i guess and the SSD for games. I got 142GB left on the SSD and 42GB left on the Main one
I'm sure you are aware but if an SSD goes bad, data recovery is impossible.
So if you want to upgrade a bit, I'd look into a standard HDD spinning drive for data backup.
HDD spinning drive? so you mean if my ssd will go bad the data will still be in HDD?
Correct, you can set up an automated backup from the SSD to the HDD, so if the SSD fails, then you still have your data on the HDD.
Note: Only backup user-created data, programs would have to be re-installed anyway, so no real point in backing them up.
This will at least give you a safety net.
Otherwise, we can talk about how the temps are in your system, and airflow and whatnot.
Yeah thanks. The temp is good i think and the airflow, idk the pc has 5 fans so should be good ? 😄
What program do you monitor your CPU and GPU temps with?
FurMark, Core Temp and i guess MSI Afterbruner
Ok, CoreTemp is nice as it sits resident and watches the CPU.
I use GPUTemp to watch the GPU temps, also sits resident
AIDA64 can monitor the mobo temps, but it's got a LOT of options, so a bit of a learning curve.
On the other hand, you can do neat things like this with it:
That's an inexpensive 7" Raspberry Pi panel, customized to show temps of the system.
I just picked one of these up and have been making my own panels through AIDA64. It's a lot of fun.
Yeah, that's kinda cool, i might get one of those 😄 Anyway, i wanted to ask maybe you know any good pc's for streaming, gaming so I can look into in the future 😄
Well to be honest, I'm not really a gamer, so in that regards I'm not the person to ask. I'd venture your system is pretty good for that as it stands, lacking the mic, perhaps a second screen, and a way to record your games being played (which can be done through something like this: https://www.elgato.com/en/game-capture-hd60-s )
There will be others to come along I'm sure, you are much more knowledgeable about streaming games, who will help you better than I could.
Are you currently running single or twin monitors?
Ok, thanks 🙂
4 hours ago, Rubah said:
I think its Radeon RX 580 Series if i'm checking it right
The RX580 is going to be very outdated soon, especially because it's memory is GDDR5, and all modern GPUs are on G6 memory. I'd recommend upgrading GPU to a RTX 2060-RTX 2060 super. If u can, upgrade CPU-mobo combo to a i5-10400 or i5-10500 and a Asus or Asrock b460 motherboard. If u do Cpu upgrade, upgrade to a 3060, 3060 ti, or 3070.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
He shouldn't upgrade as of now,wait for 8-9 months if he doesn't currently encounter problems in games.
Now is the absolute worst time to upgrade.
I have to disagree on the CPU upgrade,not worth it,save the money and wait for 12th gen since making the upgrade to a 10400f so includes a new motherboard for what is pretty much a small upgrade.
If it is that, you might a rtx 3070 because it is cheap starting at only $499.99, idk what price it would be at where u live, but yea. if not that, you can get a rx 5700xt, idk what price that would be either where you live too 🙂
Agreed. Gpus are insanely hard to get right now, and for a horrible price.
Gaming PC:
