Usually if i leave my pc shut for a long amount of time i have to restart it multiple times in order to get it running otherwise i get no signal error. Anyways, today no matter how many times i restarted it i didnt get any display. I thought my mb was dead since its been 6 years since i bought it. But when i unplugged my rx 570 (2yrs old) out and used intel hd it booted up perfectly. but when i plug the rx 570 and then use intel hd i dont get any display. so is my gpu dead or is it my psu or something? Specs:
RX 570
W10
12GB Ram
i7 4770
Gigabyte H97M
Thermaltake Smart 500W RGB
Any help appreciated
https://linustechtips.com/topic/1321704-is-my-gpu-dead/
RX 570
W10
12GB Ram
i7 4770
Gigabyte H97M
yes
https://linustechtips.com/topic/1321704-is-my-gpu-dead/#findComment-14612320
