So i recently brought 2 Seagate barracuda 4tb internal drive which I have had for about a week and when i went to boot my computer this Moring i got my motherboard reporting a smart error with one of the drives so i download Seagate drive diagnostic tool and it came back as fine so I try to move some file to and from the drive and they were fine the drives is not getting hot and sound fine as well so i was wondering what to do should just ask to retune the drive
the reason I’m asking here as I haven’t come across these Seagate S.M.A.R.T. error before
Thanks and please for give the complete lack of any punctuation
https://linustechtips.com/topic/1321595-seagate-smart-error/
SMART errors are a standard error reporting type (although all manufacturers use them slightly differently). But if a drive produces a SMART error, it can be as simple as a warning all the way to imminent catastrophic failure of the disc.
Seagates tool is not reporting any SMAR errors though? They are stored on the drive, so if your motherboard saw them, software should as well. Are you sure the software isn’t reporting any?
https://linustechtips.com/topic/1321595-seagate-smart-error/#findComment-14611509
