Is it worth to replace a h80i v2 for a Freezer II 280?
Solved by Tonyx,
6 minutes ago, LeTuga said:wich i believe is a little to much.
yeah i think so
6 minutes ago, LeTuga said:Do you believe it will make a difference?
yes, your 120mm aio is clearly very busy due to very high consumption of the cpu
so yeah a 280mm aio (and quite good one) is certanly more suitable for the cpu
8 minutes ago, LeTuga said:And by the way, do you know if they will fit my case?
yes. but looking at your case seems a case with poor airflow, has very little mesh surface to "breath"
