Hey
I have an gtx 1650 4gb and i had an 768p monitor but now i got a new one 1080p and i wanna use both but my graphics card only has a hdmi and displayport but both monitor only have hdmi so i bought an displayport to hdmi adapter
[16:07]
but idk why its not working
https://linustechtips.com/topic/1320998-display-problem/
There are many of those, because DVI had like 6 standards, perhaps you bought the wrong adapter.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1320998-display-problem/#findComment-14606760
I was talking to a friend and he told me that never hdmi and display port conections on the same card will work
because one is digital and the other one is analog our something like that im not really sure if that is true but if u have any ideas what could be i  would be apreciated
https://linustechtips.com/topic/1320998-display-problem/#findComment-14606773
I use DVI to HDMI connectors all the time, work fine, provided you get the right one.
They are both digital connections. Only analog is VGA, and you don't use that.
https://linustechtips.com/topic/1320998-display-problem/#findComment-14606873
No, they are both digital.
Silly question. Did you download the graphics driver and reboot? Or did you just only plug the monitors in?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1320998-display-problem/#findComment-14607647
