I'm not sure this is the right place to post this.
I put a filter in one of my case fans later on I started to smell some burning plastic. when I open and notice that side case fan was not spinning. I also notice that all the fans were not spinning. keep in mind the case fans I'm talking about are one has there own controller and with RGB connected to the PSU, but also the fan that is connected to the system fan header was also stop working stopped. I turned off the computer and removed the filter and replace the fan that was stuck and burning. it seems all fans are now spinning. I don't know if its something to do with the controller, PSU, or the motherboard see a problem and turn off all case fans. I can tell nothing is wrong with the computer as I'm type out this topic. just worry if something else might happen.
https://linustechtips.com/topic/1320807-case-fan-issues/
sorry bro. This is so poorly worded that it is difficult to help you.
Can you provide pictures and reword your problem a bit better?
No offense. People here genuinely want to help you.
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
https://linustechtips.com/topic/1320807-case-fan-issues/#findComment-14608278
