ASUS Ryuo 240 not showing AIO PUMP Speed in ArmoureyCrate/On screen
TrainNutter
Hi!
For some reason my ASUS Ryuo 240 does not show the PUMP RPM in the BIOS or in Armorey Crate
The cooler works fine as i just saw now it reduced the CPU temp from 55 to 38*C (Idle). But on the on-board screen its showing Pump RPM to 0. How can i fix this?
PC parts:
AMD Ryzen 7 5800X
ASUS ROG STRIX Ryuo 240
ASUS ROG STRIX B550-E Gaming
Gigabyte GeForce RTX3060 Ti Gaming Pro OC
Corsair MP600 Core 1TB NVMe PCIe 4.0x4 SSD
Corsair Vengence RGB Pro 2x(2x8GB) 3600MHz CL18 (@3400MHz due to instabilities)
Corsair iCUE 4000X RGB Case
Corsair SP120 Elite (x3)
Corsair CX650F RGB
6 hours ago, narrdarr said:
which fan header is the pump plugged into?
AIO PUMP & its fans to CPU OPT
try switching to the header or pump header instead of CPU opt. CPU opt usually just mirrors the CPU header unless manually changed in bios.
aah ok cheers! I'll try that when I get home!
