ssd and hard drive question
Solved by C2dan88,
Those files come in the visual C runtime library which should get installed by apps that require them or windows update automatically.
Try (re)installing the visual C 2019 runtime library (both x86 and x64 versions) from here
Also run sfc /scannow too
