18 hours ago, kamikazi33 said:
i'm looking for a laptop under 800$ for school if anyone could help me with a recommendation for what i would need for machine learning
Are you getting started with ML? If so, then I'd actually recommend against getting a laptop for it (performance will be shit unless you go for workstation models), and instead make use of google colab or just go for another cloud service, it'll be more powerful than any laptop you can get in that price range and also cheaper (colab is free!).
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
