What is your current audio solution?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1319840-recommendation-for-dac/#findComment-14597144
3 hours ago, celerystruct said:
I have my headphones plugged into the headphone jack on the back of my mobo. Would a sound card also be something I could look into?
You're going to need both an AMP and DAC if you want a DAC. I'd usually recommend going with a Schiit Stack and grabbing a Magni and Modi, but that exceeds your budget.
Are your headphones not getting loud enough? You need an AMP. Are you encountering distortion? You need a DAC. Unless you have shoddy onboard audio, investing in an AMP/DAC may not improve your listening experience.
Desktop
Homelab
https://linustechtips.com/topic/1319840-recommendation-for-dac/#findComment-14597163
17 minutes ago, PorkishPig said:
You're going to need both an AMP and DAC if you want a DAC. I'd usually recommend going with as Schiit Stack and grabbing a Magni and Modi, but that exceeds your budget.
Hmm in that case I think I'll keep the Schiits in mind but hold off on getting anything for now. Thank you for the help.
https://linustechtips.com/topic/1319840-recommendation-for-dac/#findComment-14597204
1 hour ago, celerystruct said:
I am looking for recommendations on a good DAC. I own a pair of sennheiser hd 58x. My budget would be no more than $100 and I am located in the US. Thank you.
I would say the sound blaster G5 or G6
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1319840-recommendation-for-dac/#findComment-14597233
