6 hours ago, cak said:
mt ethernet is connected when the computer starts but after i login into a mc server or do a web search it suddenly becomes no internet so i need to use wifi but its slower ..........help
Update the LAN drivers from the motherboards website & if the problem still persists, buy a higher quality, standard(Cat6/Cat 7) Ethernet cable of the shortest length possible.Many a times the wiring in the Ethernet cable is not done properly.
If the issue still persists, try changing the router/modem settings like LAN port settings, data saving options etc..
Lemme me know if the problem still persists....
Ryzen 5 2400G -B450M DS3H Motherboard (Gigabyte) - 16GB RAM (CL 16, 3000MHz) - 240GB SSD (Kingston) - 1TB HDD(Seagate) - 450W PSU (Corsair)
Honestly it sounds like driver issues I've had in the past. (Let me guess - Realtek?....)
Update your drivers if possible (look on your motherboard manufacturer's website if Windows doesn't detect any available updates)
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
