I have a commerce assignment due tomorrow. I'm in year 10 and they introduced a new policy where if you don't hand it in by the due date you will get zero. Problem is I have only done like 1 paragraph. I don't have the sheet anymore so I have no idea what to do. I emailed my teacher but he isn't responding. What should I do?
https://linustechtips.com/topic/131885-i-need-help/
Shoulda done it when it was first assigned
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/131885-i-need-help/#findComment-1754980
not have gone and made a post here and gotten on with school work
Specs
https://linustechtips.com/topic/131885-i-need-help/#findComment-1754997
You're fu*ked.
Try emailing someone from the same group that your in?
Take the zero. And do the homework or whatever next time.
I've been there lel
When you're looking in it's kinda funny.
We have google sites for school and every other assingment I have is on the google site except this FU*KING ONE!
https://linustechtips.com/topic/131885-i-need-help/#findComment-1755001
Year 10 is bludge (at my school at least) Just roll with it and remember to do it next time to bring your grades back up. Unless it's end of year stuff. Then your slightly more fucked.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/131885-i-need-help/#findComment-1755063
