Seagate Hard Disk Problem
Go to solution Solved by TUnknown,
Thanks for you guys for helping me i contacted the Seagate team and i got my drive to a recovery centre
For anyone who comes across similar problem you can visit (www.seagate.com/retailwarranty)
I'm new to the forum, so please forgive it i post it the wrong place but i really needed some help
I bought a Seagate 2 TB hard disk and i have used it for about 1 or 2 year with no problem at all but then suddenly when i plug it in it beep 2 times and windows recognize it, but it does not show up in my PC or Disk management
but device and Printer recognize it but i can't access it and i try finding a solution but all the solution can see the drive in disk management but i cant see it
The Device is Seagate BUP Slim BK Just for Reference
I have tried Uninstalling driver ,restarting the computer, changing cable and changing device but the problem is itill there
https://linustechtips.com/topic/1318495-seagate-hard-disk-problem/
Beeping is a signs of problem, usually bad power connections due to worn out usb cables / port.
2 minutes ago, TUnknown said:
nothing there just empty space
Have you tried it on another PC?
Can you feel the drive spin up when you plug it in? If not, the drive might be dead or the port could be damaged. If it's out of warranty, you could remove the drive from the enclosure to see if it detects using a SATA interface.
ya it is spinning and windows has the sound when plugging into the port but the hard disk beeps twice when i plug it in which did not happen before
3 minutes ago, TUnknown said:
but i try to plug into all the available port and i even tried on another pc but the problem persist
The problem is not the port on the PC, it's the port on the drive which is not durable.
Also constant replugging will reduce the lifetime of the drive, creating bad sectors, this is a common problems with usb powered hdd.
If you can connect the drive, rescue as many files as possible, that drive is about to be dead.
Next time buy a external usb drive with dedicated power adapter.
I plug into the 2nd pc to transfer some files, and it worked fine but after plugging it into the TV it did not recognize it so i used the pc to check if the drive is ok, but then it just started to beep whenever i plug it in and i cant find the drive anymore after that
  • 3 weeks later...
