I wouldn’t do water cooling cuase it’s louder and it takes more maintenance and it’s more expensive and there more likely going to bit the dust faster and when they do it’s going to cost a lot to fix and it takes a long time to fix. And when it fails u can’t fix it but with air cooling let’s say one fan fails on a tower cpu cooler u can just take the broken fan off and take a case fan and slap it on boom done.
https://linustechtips.com/topic/1318077-water-coolers/#findComment-14583242
12 minutes ago, Rafail said:
The fan will work perfectly but I cant change the rgb right? If i use  the rgb hub that comes with the 3 pack ll120 from corsair will it work?
The fans will power on, but you will not be able to interface with Corsair's RGB software.
The RGB hub that comes with the LL's is also specific to Corsair fans. They are not meant to be used with other brand fans.
https://linustechtips.com/topic/1318077-water-coolers/#findComment-14583639
Ummm, no. You might as well try to say they leak all the time too because it's just as false. Unless you're doing a custom loop and/or the motor goes boom in an AIO it doesn't cost more and even if the motor goes boom in an AIO you've got a warranty unless you paid $5 for the whole unit. It's also not louder unless you pay like $5 for the cheapest water cooler out there with a diesel engine. It's not more maintenance unless you do a super expensive custom loop and at that point you know what you're doing and what you're getting into.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1318077-water-coolers/#findComment-14583811
ok,thanks
Rafail.ps
https://linustechtips.com/topic/1318077-water-coolers/#findComment-14586967
