Cleaning Radiator
Go to solution Solved by bowrilla,
Radiators aren't picky with what you use to clean. There's no risk of sucking in small components (unlike with other parts). Just be careful not to handle it too roughly or you might damage it (ranging from optical damages like bent fins to potential leaks)
So I've had an aio for about a month now but live in a very sandy area so it has accumalted a year's worth of dust in a month, so I was curious on how to clean it? So far I just took a brush and dusted it out, but could I use an AC Cleaner on the radiator fins? (similar to the picture of the can attached).
Ra504d8c3b4c4b9dff3eef539465e0a57.jfif
https://linustechtips.com/topic/1317665-cleaning-radiator/
Couldn't you just use a air compressor? Or datavac?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1317665-cleaning-radiator/#findComment-14580007
21 minutes ago, NLamki said:
yes but wouldn't the ac cleaner do a more thorough job?
Idk. I live in a place where AC isn't widely used. I wouldn't imagine that it would get that dirty, only dusty 🙂
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1317665-cleaning-radiator/#findComment-14580053
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1317665-cleaning-radiator/#findComment-14580250
