Monitor your SSD temperatures. 970 Evo tends to get hot when under heavy load and throttle.
https://linustechtips.com/topic/1317422-ssd-problem/#findComment-14578345
405 gb and  on the other 300gb empty space. In sentetic performance both are close to the advertised values. But when I try to transfer between them it sometimes does 2gb/s the whole run even with lagrger files (10gb+), but in most cases it starts at around 400mb/s and the plummets to 9mb/s and then every once in a while it goes back to 400mb/s.
And sometimes(one in ten) it starts at 9mb/s and then goes up to gb/s oder the course of 1 minute.
I just don't understand why.
System: Ryzen 5 3600x, Asus x570, 970 evo pro 1tb (Systemdrive), sabrent rocked 1tb, 1tb sata ssd, 1 tb hdd, 32gb 3200mhz ram,
https://linustechtips.com/topic/1317422-ssd-problem/#findComment-14578365
