suggestion Upgrade from LG G6 - Android Phone Recommendation
Solved by dizmo,
I'll just throw the Samsung S20 FE out there. You can get them for around $599, and it would do most of what you want.
If you really enjoy using the camera, might be worth seeing what the OnePlus 9 Pro is like (comes out on the 23rd). It'll likely be slightly north of $1,000, but if you keep your phone for a while it might be a good bet.
Some things to mention:
- Most phones with a macro camera, the set up is absolute trash and not really worth having. Those that are decent won't work well in Canada.
- MP is one of the last things you should focus on when it comes to a camera. Pixel size, pixel binning, sensor size all play a much larger factor in quality.
- Faster phone navigation will simply come by having a newer SoC; anything 800 series will be snappy in comparison. You can also install custom launchers to increase the snappiness feel.
If you're on a carrier with a contract there are other deals to look at.
