What CPU Fan
Solved by DamDirtyApe,
Enermax Magma These are the weakest of the bunch. But they also have features like removable blades for easy cleaning. You just pull them off. Fairly quiet, but at high speeds they sometimes tick. I use to run these, but moved onto Noctuas since.
