You can't put different cards in SLI.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749773
It won't work...
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749774
Y NO ONE TELL ME WHAT HAPPRNS IF I DO Q.Q
nothing will happen, i don't think it will even give the option to SLI. Satisfied?
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749805
Just try it if you really want to know...
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749811
If you plug in the both cards, both will be recognised by Nvidia's software, and by Windows. Nothing 'bad' will happen like them blowing up or anything.
You just won't be able to enable SLI functionality. That's all. You can use the cards separately for things like GPU acceleration in BOINC and Folding@Home.
SLI will be unable to be turned on. That's it.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749850
Jesus christ, are you like 10 years old?
He sure is very impatient and immature.
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1749871
soryy i didnt sleep 1 night and no one listen to me > :( everyonr gave me shady dodging abswers
Dude, my english is bad but at least I know how to write words... abswers, everyonr, soryy... at least make an effort while posting here.
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1750143
What if i accidentally put a 560 ti in sli with 550ti? They kinda look the same... i have a 560 ti ref i think and a 560 ti thats from msi what happens if the ref is a550 ti and i sli?
Isn't it the better choice to ask us how to find your card model out? >.<
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1753401
idk dafuw it is i have a gtx 560ti hawk from msi and a 560ti ref
SO no GTX 550 Ti?
https://linustechtips.com/topic/131490-help-different-card-sli/#findComment-1755325
