Question to all, my pc windows 10 pro 32 gigs of corsair vengence 3200mhrtz. 650what corsair power supply. 1070ti ftw ultra silent 8gig model. CPU. i7 8700k at 4.5 ghrtz.on a corsair 280m rgb platinum aio. I have been having problems with my moniters turning off and pc fans turning to 100% but the pc is on and people in discord can hear me. just wondering if anyone has any tips for me to fix it. Thanks
https://linustechtips.com/topic/1314693-pc-issue/
Welcome!
Which fans are ramping up (CPU, GPU, or case fans)? From what you describe it sounds like the GPU driver is crashing.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556054
1 minute ago, RAS_3885 said:
Welcome!
its sounds like all of my fans ramp up to 100% and it restarts fine. latest drives and bios. all that i can see in event viewer is a kernal power thing. i can send the event viewer if u can make sense of it
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556058
3 minutes ago, RAS_3885 said:
Welcome!
If the driver is crashing, you can always hit these 4 keys to reset the Gpu driver sub system.
Win + Ctrl + Shift + B
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556059
Excuse me, what?!?! Has this always been a thing? That seems like a very useful hotkey.
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556064
Just now, ShrimpBrime said:
Yeah for a while. Since W8 for sure.
Well look at that... TIL! Neat!
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556073
I have a few tricks here and there 😉
Just now, Malreath said:
is their a way for me to fix my driver from stop crashing?
Try different drivers maybe. If Geforce experience is installed, remove that.
Keep an eye on Gpu temps and v-core.
Stuff like that maybe.
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556084
Use DDU (https://www.guru3d.com/files-details/display-driver-uninstaller-download.html) to totally remove the drivers and then do a clean install of the latest from Nvidia. Ditch Geforce Experience if you're using it.
https://linustechtips.com/topic/1314693-pc-issue/#findComment-14556096
