Budget (including currency): 10000 aud
Country: aus
Games, programs or workloads that it will be used for: games and work
Other details current case Corsair 5000d air flow
(existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
Trying to understand if I'd have compatibility issues for an Intel i9xe build with an x299 wu8 gigabyte motherboard, motherboard is ceb form factor (can live with as the difference is about 2.3cm in thickness as far as I can tell.
But this is the first time using a ceb.
Will be running an rtx 3090 with future expansion to sli
256gb ddr4 2933 b4 oc
2tb SSD AIC pcie 4.0 (realising I'll be using 3.0 on the mb)
Does anyone have any advice or Sim build I can have a look at?
Any advice or support would be greatly appreciated.
https://linustechtips.com/topic/1314447-compatibility/
https://www.techpowerup.com/review/corsair-5000d-airflow/
This says it supports E-ATX up to 305 x 277 mm
https://www.gigabyte.com/Motherboard/X299-WU8-rev-10/sp#sp
This says "CEB Form Factor; 30.5cm x 26.7cm" so 305 x 267mm, meaning it should fit inside
https://linustechtips.com/topic/1314447-compatibility/#findComment-14554009
Any reason you want to have Intel i9?
Check this 32 cores monster.
PCPartPicker Part List
CPU: AMD Threadripper 3970X 3.7 GHz 32-Core Processor  ($3052.50 @ Newegg Australia)
CPU Cooler: NZXT Kraken Z73 73.11 CFM Liquid CPU Cooler  ($392.24 @ Amazon Australia)
Motherboard: Asus Prime TRX40-Pro ATX sTRX4 Motherboard  ($620.84 @ Amazon Australia)
Memory: G.Skill Ripjaws V 256 GB (8 x 32 GB) DDR4-3200 CL16 Memory  ($1879.00 @ Scorptec)
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive  ($580.80 @ Newegg Australia)
Video Card: Zotac GeForce RTX 3090 24 GB GAMING Trinity Video Card  ($3049.00 @ PLE Computers)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  ($237.51 @ Amazon Australia)
Power Supply: SeaSonic PRIME Ultra Gold 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($329.00 @ Mwave Australia)
Total: $10140.89
Generated by PCPartPicker 2021-03-12 16:26 AEDT+1100
https://linustechtips.com/topic/1314447-compatibility/#findComment-14554021
@eigenvektor thank you. 😊
https://linustechtips.com/topic/1314447-compatibility/#findComment-14554032
