Budget (including currency): 800-1000$
Country: Germany
Games, programs or workloads that it will be used for: Dota2, CsGo,COD, rpgs.
Hi
i got a i9 10850k and a rtx 3080 (got them as a gift)
can u suggest me a pc case, liquid cooler or a air one, ram, mobo. And a 144mhz monitor around 300 400$.(thats the bidget for monitor).
i have a RMX 750w power supply and enough storage.
i do not plan on overcloking anything gonna use it stock.
I do some gaming but not much. And no production is gonna be done on it.
So i dont wont to over pay on mobo or something that i dont need or wont use.
Thnx for help.
Location is germany.
https://linustechtips.com/topic/1313305-upgrade-help/
5 minutes ago, zaharyboy said:
Hi
Thnx for help.
what is your full budget for all of the parts you want to upgrade? Do size case do you want?
geometry is hard
b550 > x570
https://linustechtips.com/topic/1313305-upgrade-help/#findComment-14543674
First of all I  really sorry for not using the form to fill in info.
I will edit this post as soon as i have time. First time here using a friends account.
So my whole budget ia around 800-1000$.
Case can be a mini case as long i dont get thermal problems with it. Otherwise a normal case is fine (mid tower). No huge cases.
Sorry again.
https://linustechtips.com/topic/1313305-upgrade-help/#findComment-14543725
