so i just got the second hand gtx 960 i checked everything furmark temps clocks fan speed and everything was fine and when i put it on my system and  start furmark test it goes on 96c in like 1 second and also fans are going 100 % what should i do please help maybe its bug or something because
https://linustechtips.com/topic/1312965-need-help/
https://linustechtips.com/topic/1312965-need-help/#findComment-14540946
5 minutes ago, linusasfani said:
It doesn't look like the card can breathe.
8 minutes ago, linusasfani said:
it goes on 96c in like 1 second and also fans are going 100%
The card might have dry thermal paste because it is old
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1312965-need-help/#findComment-14540963
3 minutes ago, linusasfani said:
but when i tested on sellers pc it was grate so that was reason why i took it
Then I would guess that since the graphics card is almost touching the bottom of your case, means it can't get fresh air
Primary PC:
PSU tier list
https://linustechtips.com/topic/1312965-need-help/#findComment-14540971
how much space between the bottom of the GPU shroud and the bottom of the case? As @Fasauceome mentioned, it definitively looks like your GPU is not getting any air.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1312965-need-help/#findComment-14540973
As mentioned above by @Fasauceome I think that there isn't enough space between the bottom of the case and the GPU fan and as a bonus thermal paste might be dry since the card is old
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1312965-need-help/#findComment-14541061
so i got your all advices but i downloaded gpu-z and start furmark test it showed the same temps but when i downloaded the log file the temps are perfect  and thats obviouse
https://linustechtips.com/topic/1312965-need-help/#findComment-14541155
Could you maybe take a pic of when the bad temps show?
Reminder⚠️
https://linustechtips.com/topic/1312965-need-help/#findComment-14541159
image.thumb.png.329881281ca90a2b248103aeb0e6504f.pngand this happend after like one sec of test
Seems like dried thermal paste because higher GPU temps under load is normal but that seems pretty high
Reminder⚠️
https://linustechtips.com/topic/1312965-need-help/#findComment-14541166
maybe should i try fresh install of OS because i think that something is bugging
Did you reinstall GPU drivers?
Reminder⚠️
https://linustechtips.com/topic/1312965-need-help/#findComment-14541170
no but i will try
Yeah DDU and then reinstall latest old drivers are most likely colliding or something
Reminder⚠️
https://linustechtips.com/topic/1312965-need-help/#findComment-14541184
where should i make ddu can u link?
Here is a link but be careful and read, prepare latest GPU drivers in forehand
Reminder⚠️
https://linustechtips.com/topic/1312965-need-help/#findComment-14541190
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1312965-need-help/#findComment-14541193
