Budget (including currency): 700 max preferred 600 or less
Country:
Games, programs or workloads that it will be used for:  zoom mostly for video teaching
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): include and exclude monitor and all extras
https://linustechtips.com/topic/1312750-budget-build-help/
Not a good time to build anything budget based.
If you're using it for something simple like Zoom, just get a cheap laptop or a prebuilt.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1312750-budget-build-help/#findComment-14539408
