Monitor for work
speed258
Hello I'm looking monitor for work(documents and etc, no gaming or video stuff), looking in range 100-150 euros, currently have these choices:
Philips 273V7QDSB/00
AOC 27B2H
AOC 27B2DA
LG 27MK400H-B
Which one should I take or anyone could reccommend something else?
oh and yes looking for 27 inch monitor(I have feeling that is too big for 1080p monitor, but budget dictates rules)
Thanks.
CPU: Intel I7-8700K | Motherboard: Gigabyte Aorus Z390 Master | RAM: Corsair Vengeance 3000Mhz 2x8GB | GPU: Asus ROG 1080Ti OC | PSU: Seasonic Prime 650W Titanium | SSD: 1x Samsung Evo 970 250GB M2 1x Samsung Evo 970 1TB M2 | CPU COOLER: Noctua D15
The philips and both AOC monitors seem pretty similar; IPS, 250 peak brightness, 1000:1 contrast.
Any of them will probably serve you well.
I would, however, steer clear of the LG one - that one has a TN panel, which is good for high refresh rates and low response times, but if the monitor is just for work and no gaming then IPS is a much better choice  as it produces better colours.
