Sata Power causes my PC to not boot after GPU swap.
Solved by HelpfulTechWizard,
30 minutes ago, SgtBigmac said:Fairly cerain one of the 8-pin GPU power connectors came from a different PSU since the RTX needed a second 8pin power cable, otherwise, they are all original connectors and were working fine for the last 2 years of use with the GTX 1060
Don't do this. A good chuncb of the time a psu with modulating cables will ahve a completely new pin out for the cables, and basically no other psu will match the pinouts
