Hello I've bought a Phanteks P400 White Tempered Glass because it's a sick looking case, however I can't find information about whether a noctua NH-D15 / NH-D14 would fit in it. It'll be sitting on a ryzen 5600x with an MSI MPG X570 motherboard in case that affects clearance somehow. I've seen conflicting statements about these coolers fitting in the case online so if anyone has that combo or experience with it any information would be greatly appreciated. Thanks in advance!
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/
It does not seem like it would fit unfortunately. The case has a 160mm cpu cooler clearence, and the nh-d15 with a fan is 165mm. But this is just from the information from the manufacturers website, so i do not have any first hand experience with the combo
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531554
The D15 will not fit as it is 165mm tall, the D15S will at 160mm, also keep in mind you can move the fan up and down a tiny bit. The max height at which you can fit in the P400 is 160mm.
Other large air coolers I can recommend that will fit are the Scythe Ninja 5 and DeepCool Neptwin.
In the future you can use https://pcpartpicker.com/list/ it has a compatibility filter and if you select hardware you already own it will only show what is compatible.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531571
Genuinely didnt know that, thank you!
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531578
No problem, also for the 5600x I would go for one of the other two coolers I mentioned, they are not far off the D15S and they cost a lot less (depending on region).
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531582
I'm really keen on Noctua due to their basically legendary reliability and performance but I'll 100% look at those!
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531601
How accurate would the PC part picker thing be? It lists the p400 as compatible with the NH-D14 and I've seem some images of builds with it in them, but also alongside those "it'll never fit comments". Theoretically if the top op the cooler (the pointy bits going through the fins) was touching the glass could I expect it to crack from heat?
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531756
All air coolers form reputable manufactures are going to be just as reliable as competitors, pretty well the only thing that might fail is maybe the fan one day. D15 vs the Ninja 5 / Neptwin with a 5600x will not give you any real performance gains, maybe a few degrees C of difference at most.
From what I can tell the D14 is slightly taller than the D15. So I would avoid it.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531927
Corsair A500 cooler is bad thow...
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14531957
I never recommended it...
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14532432
https://linustechtips.com/topic/1311780-cooler-fitting-in-case/#findComment-14532490
