Budget (including currency): 1500-2000 CAD
Country: Canada
Games, programs or workloads that it will be used for: Some random gaming, heavy VM setup
Here is my existing cart from newegg.ca but not sure if its accurate or not:
Case: https://www.newegg.ca/black-fractal-design-meshify-c-tg-atx-mid-tower/p/N82E16811352084?Item=N82E16811352084
Motherboard: https://www.newegg.ca/asus-tuf-gaming-x570-pro/p/N82E16813119353?Item=N82E16813119353
Power Supply: https://www.newegg.ca/seasonic-focus-plus-750-gold-ssr-750fx-750w/p/N82E16817151187?Item=N82E16817151187
Processor: https://www.newegg.ca/amd-ryzen-7-3800x/p/N82E16819113104?Item=N82E16819113104
SSD: https://www.newegg.ca/samsung-970-evo-plus-1tb/p/N82E16820147743?Item=N82E16820147743
HDD: https://www.newegg.ca/seagate-barracuda-st2000dm008-2tb/p/N82E16822184773?Item=N82E16822184773
RAM: https://www.newegg.ca/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232476?Item=N82E16820232476
Cooler: https://www.newegg.ca/cooler-master-hyper-212-rgb-black-edition-rr-212s-20pc-r1/p/N82E16835103277?Item=N82E16835103277
Please suggest what's wrong with this or what can be added. Any latest graphic card is out of stock. So I can go with integrated for now.
I am also building it from perspective of easy future upgrades.
Current cart value: ~1500 CAD
https://linustechtips.com/topic/1311400-help-building-a-new-pc/
Country: Country
I doubt there is a difference in performance between the 3700x and 3800x worth 60 CAD. Maybe there is, someone else can disagree here if they think so.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528655
What do you mean integrated? Only the APU line of of chips from AMD have graphics processing capabilities. If you want graphic output your gonna need some kind of GPU even if its really old like a 900 or 700 series card.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528733
if you want to use integrated graphics you should pay the extra 10 bucks for a 9900k over the 3800x
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528735
I went and made the build on PCPartPicker, just a little easier to sort through that way. Also used a 3700X over the 3800X
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($419.99 @ Newegg Canada)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  ($53.00 @ Vuugo)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($234.00 @ Newegg Canada)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($129.99 @ Newegg Canada)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  ($199.99 @ Amazon Canada)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($64.99 @ Canada Computers)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($124.00 @ Vuugo)
Power Supply: SeaSonic FOCUS 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($144.99 @ PC-Canada)
Total: $1370.95
Generated by PCPartPicker 2021-03-02 14:03 EST-0500
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528740
PCPartPicker Part List: https://ca.pcpartpicker.com/list/7fGcvf
CPU: Intel Core i9-9900K (Standard Folding Box) 3.6 GHz 8-Core Processor  ($499.99 @ Newegg Canada)
Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard  ($139.99 @ Canada Computers)
Total: $1356.94
Generated by PCPartPicker 2021-03-02 14:09 EST-0500
9900k build for if you don't already have a gpu
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528754
Any budget graphic card you can suggest which can output at 144hz? Again, I have a PS4 for gaming so prime focus on this PC is not gaming. That's why don't want to spend 1000 dollars on a graphic card.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528762
Just get the cheapest used GPU you can find. If your not gonna be doing much gaming, the the refresh rate of the monitor shouldn't matter for non gaming purposes.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528772
displayport on the intel motherboard supports 4k 60, so it would support 1440p high refresh rate should be fine
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528786
2 minutes ago, curiousmind34 said:
amd is generally a bit less stable than intel. (intel better be stable after 14nm+++++++++) and intel tends to do better in single threaded loads and amd is a bit better in multithreaded loads.
Makes sense. ! more question: is single Cooler master CPU cooler should be enough or there is a need to include additional fans with a radiator (front or top) in the build?
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528804
I was planning to go for this GPU initially: GTX 1030 https://www.newegg.ca/gigabyte-geforce-gt-1030-gv-n1030oc-2gi/p/N82E16814932004?Item=N82E16814932004
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528809
2 case fans should be fine. I have this cpu and had that exact cooler in an h510 with the included 2 case fans, it would heat up to 99c after 20 mins of sustained load, but I haven't really seen it throttle. In real world use case it doesn't throttle because I'm not hammering it at 100%, so unless you do that, the included case fans should be fine.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14528847
1 more thing. I notice that Motherboard: MSI Z390-A PRO ATX LGA1151 Motherboard says that when 1 M.2 is used, SATA port gets disabled. Are all the SATA ports disabled or only 1?
it disabled sata ports 5 and 6. The other 4 work fine
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14529060
14 minutes ago, Shobhit Bhardwaj said:
Also, does this motherboard supports SSD boot? In case I don't plan to buy HDD
yes, I am typing this to you on my motherboard which is booted for my m.2 drive. Even if you did end up buying an hdd, I reccomend storing an os on an ssd because it’s much faster to boot. You can configure boot priority in the bios.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14529158
25 minutes ago, Shobhit Bhardwaj said:
is 750W power supply an overkill right now or future safe in case I add a RTX 30 series graphic card? @curiousmind34
its not overkill; if there is more than a 20% chance of you getting a 30 series graphics card I would pay the extra 25 CAD.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14529268
27 minutes ago, Shobhit Bhardwaj said:
That is pretty horrible. Why are you looking at a 9900K and Z390 ? The i7 10700K is cheaper. Also that board is not ideal for a 9900K and I doubt the cooler is good enough either. The 9900K runs hot.
Do you need wifi 6 ?
The HP EX950 1TB is cheaper.
Also Z590 is out and the 11th gen is due this month. That might have an effect on current prices.
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14529386
Hmm, here are my thoughts:
1) I prefer to get a 11th gen intel but that is a month away and will increase cost of build
2) I can go AMD way with latest 3rd gen chips, but those does not have integrated graphics. that means I have to get a graphics card which are rare in market to get hold off
3) I prefer wifi6 because I already have Asus Ax86U wifi6 router with 1 Gig Up/Down connection and it's better to have a build which already have Wifi6 card
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14531852
The 11th gen is out this month, so maybe 4 weeks to wait max. You should at least see what prices/reviews are like. If you want something now then the i7 10700K is cheaper than the 9900K. It doesn't make sense to buy a cpu that will be 2 versions old in a few weeks.
The Ryzen cpu's don't have onboard graphics but you could put the cheapest gpu in there for the short term. You won't be doing any gaming with onboard graphics anyway.
If you need wifi 6 then fair enough.
Here is a 10700K build if you don't want to wait.
No RGB but you can swap out the Ram if you want the Corsair etc.
The Noctua D15S is a better cooler than the CM 212. The Intel cpu's can run hot so you want a good cooling solution.
The MSI board has wifi 6 onboard.
CPU: Intel Core i7-10700K 3.8 GHz 8-Core Processor  ($439.50 @ Vuugo)
CPU Cooler: Noctua NH-D15S chromax.black 82.51 CFM CPU Cooler  ($119.95 @ Amazon Canada)
Motherboard: MSI MPG Z490 GAMING EDGE WIFI ATX LGA1200 Motherboard  ($279.00 @ Newegg Canada)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($99.99 @ Memory Express)
Storage: HP EX950 1 TB M.2-2280 NVME Solid State Drive  ($143.99 @ PC-Canada)
Total: $1351.42
Generated by PCPartPicker 2021-03-03 18:06 EST-0500
https://linustechtips.com/topic/1311400-help-building-a-new-pc/#findComment-14531971
