I have a groupe of things in device manager without drivers, and am looking for the drivers,
Im not sure what any of these do, except the 3 pci ones probably have something to do with pci based stuff.
specs
b250m bazooka
i5 7400
rx480 reference
can give any other relevent specs if needed.
thanks.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1311184-help-finding-drivers/
These are related to the motherboard. You can go here https://www.msi.com/Motherboard/support/B250M-BAZOOKA#down-driver&Win10 64 is the msi driver page for your motherboard
If my answer is correct or is helpful please mark it as the solution. Quote me in your post to summon me. Beware that after summoning me ill never leave.
https://linustechtips.com/topic/1311184-help-finding-drivers/#findComment-14527117
I'll have to go through them again, but I think all of thm are installed.
But I need to sleep, so I'll do that in like 7 hours.
Bios database
prior build:
https://linustechtips.com/topic/1311184-help-finding-drivers/#findComment-14527119
try installing only the drivers in the chipset category
https://linustechtips.com/topic/1311184-help-finding-drivers/#findComment-14527121
Just now, Gamer4714 said:
try installling only the drivers in the chipset category
Will do, but I need to sleep, so I'll do that in 7-8hours.
Bios database
prior build:
https://linustechtips.com/topic/1311184-help-finding-drivers/#findComment-14527124
