Using a PWM splitter on CPU header?
Go to solution Solved by narrdarr,
should be fine
My motherboard only has two fan headers and I'd like to run 3 case fans (Noctua NF-A14, 2x NF-A8) and the CPU fan cooler itself (Noctua NH-L9i).
Is it okay two use a PWM fan splitter (Noctua NA-YC1) on the SYS fan header and another fan splitter on the CPU header?
I'm trying to avoid using a fan hub since it's a mini ITX build and I have little space for cable management.
https://linustechtips.com/topic/1311103-using-a-pwm-splitter-on-cpu-header/
