Replacement 3D Printer
IMO, and to keep it really simple, there are 3 price points of 3d printers you should look at:
$300 - Get an Ender 3 (or Pro) and a few upgrades for it (mainly BLTouch and a magnetic PEI build plate for convenience) Any less for a prebuilt and you are likely getting a POS, and a DIY kit for less is unlikely to perform as well as the Ender 3. On the other side of the budget, maybe consider the $500 ish to build a quality Prusa i3 clone, just know you'll likely spend a lot of time tweaking it.
$1,000-$1500 - DIY a really nice printer like a Hypercube, Voron, Ultimaker clone, etc. Go all out with ballscrews and linear rails. If you are going to spend $1000 on a prebuilt, I think you'd be much better off building a better one for the price. You're invested this much into it, so obviously you are taking the hobby fairly seriously and should learn the mechanics of the machine anyways. Maaaybe consider a Prusa here, but IMO they are pretty lacking for being nearly $1k.
$5k - "Professional" level prebuilt printer like an Ultimaker or Makerbot. This is where you want something that just works and has a tech support team who can help when you have problems.
Basically throwing all of this out there so you don't have to wonder "If I just spend $50 more will I get a way better printer?" because I really don't think you do, it takes a pretty major bump up in budget to get a noticeable quality improvement over the Ender 3. I did see a lot of good things about Anycubic when I did my research, but didn't look too much into them. This is all assuming you want to just print "normal" things with PLA/PETG. If you are planning on really tall or long items, or printing oddball filaments then its a whole different can of worms to look into.
Finally, in a nutshell I'd recommend you get one of the Ender 3 variants.
