So I currently have a system that has a 1600X, with 16Gigs of ram and an old B350F board in it. I have seen people just use random SSD/HDD as there boot drive when that swap over from PC to PC. So I guess my question is, Can I use my SSD that currently has windows 10 on it, and swap it over to a new Motherboard, CPU and ram combo, for example over to say a R5 3600 with it's respective chipset and memory?
Note: I'm guessing I'll have to uninstall things like chipset drivers rights?
https://linustechtips.com/topic/1310545-swapping-components-over/
Windows 10 is pretty good at sorting things out. I have seen posts suggesting success simply plugging in the old drive and letting Windows sort it out. Personally I think a motherboard/cpu change is a great time to rebuild the system drive. I like to uninstall, wipe the old drive and reinstall everything.
Windows is pretty flexible these days.  You don't really need to uninstall anything.  Honestly the biggest headache will probably be re-activating Windows 10.  I will support the commenter above and say it's usually just a better idea to do a clean install on a new build, especially if you are changing from AMD to Intel or vise-versa.  Backup your steam library and important docs and go from there.
System 1:  AMD Ryzen 9 5900X | MSI X570 MEG UNIFY | 32GB Crucial Ballistix DDR4-3600 | Nvidia RTX 3090 FE | custom loop (3x 360mm rads, Optimus Foundation AMD CPU Block, Bitspower BP-VG3090FE, Aquacompter D5 NEXT, Radikult O11D-XL UNO) | Seasonic GX-1000 | Lian-Li PC-011 Dynamic XL (black & silver) | Windows 10 Pro x64 | 512GB Toshiba RD400 NVMe (OS) | 2x 1TB Sabrent Rocket NVMe in RAID 0 | 6.4TB ioMemory PCI-E storage | 55" LG C9 OLED
System 2:  AMD Ryzen Threadripper 2920X | MSI X399 Gaming Pro Carbon AC | 32GB G.SKILL Ripjaws V Series DDR4-3000 | AMD 5700 (flashed with 5700XT bios) | custom loop (1x 280mm rad, 1 x 120mm rad, Optimus Absolute Threadripper 3+, Heatkiller IV for reference 5700, Aquacompter D5 NEXT, Alphacool dual-bay res w/ D5 mount) | Seasonic GX-850 | Silverstone FT-02 (red/black) | Windows 10 Pro x64 | 512GB Toshiba RD400 NVMe (OS) | 2x Seagate 4TB SSHD in RAID 1 via LSI 9265-8i | 55" LG C9 OLED
Laptop:  Dell XPS 2-in-1 | 15.6" 4K Ultra HD Touch-Screen | Intel Core i7-8705G | 16GB Memory | AMD Radeon RX Vega M | 256GB SSD | Windows 10 Pro x64
