Almost 3 years ago, I bought an EVGA GTX 980 FTW. A few days after, I started to notice that after doing something graphically intensive, like playing games, my monitor would randomly turn black. Turning down the clock speed made it happen less often. I was thinking of doing an RMA, but I bought this card sealed from a seller on Ebay and the warranty was non-transferable. Just recently, I found out that this wasn't an isolated occurrence and that many people have had problem with this same model. Is there something I could do or am I out of luck?
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/
Did you check the display cable?
Or try a better cable?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/#findComment-14519460
I've tried an hdmi cable instead of a mini display port and the same thing happened. When I search gtx 980 FTW black screen problems on google, there are other people who get the same thing so I assume my graphics card is at fault.
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/#findComment-14519481
I got the same problem on a GTX 970 I had in the past. It died, and I got a new one from EVGA back then, but that was after 2 years and 9 months of use. Highly overclocked by the way....
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/#findComment-14519499
I assume you got a new one within your warranty period though? Also, mine crashes even if I'm at stock clocks or underclocked.
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/#findComment-14519554
Yeah, EVGA sent me a new one after I sent the broken one back. That was 2 years and 11 months after the purchase. The warranty was good for 3 years total. It wouldn't crash without any load on it, but as soon as I launched any game (I was playing Diablo 3 back then), the screen would go black.
https://linustechtips.com/topic/1310214-gtx-980-ftw-problems/#findComment-14520185
