Website help ( chain critical requests )
Solved by SupaKomputa,
You're using to many custom fonts, try reducing the varieties.
Where do you host the website?
Loading stuff from external website is okay, it decreases the latency since the user are downloading the code much faster from CDN server instead of yours.
I suggest using Cloudflare to boost your pageload.
DARTHDIVIDER0213 ·
Posted in Troubleshooting3 -
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
