PS4 and soundbar
Solved by A.Hruskach,
None of those will damage your equipment, but some may be incompatible. Linear PCM is the default and will work best for gaming. The other options may have slightly greater fidelity (quality), but only some devices support it.
Feel free to switch between them to see if you can hear a difference. If it doesn't work, just simply change it back.
5
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming7
