As long as the BIOS is not getting reset back to default specs after unplugging the power cord and draining any residual charge left in the computer system, the battery is fine. If you see any corrosion (I've personally never seen it on a button cell battery in a computer yet), bulging, white powder, or dirty contacts, you should be fine without changing the battery.
4 minutes ago, Tannah said:
If your worried you can get a voltage tester, and test the voltage its putting out. I think it should be 3.3v DC
Do you mean a voltmeter? I'm pretty sure they will provide a false reading as if you check with VDC, the battery will shows close to 3.3V. The battery has to be under a load if you use a voltmeter, unless your referring to a battery tester such as one of these. image.jpeg.1813118ccbcb72a93a011e4916833a0b.jpeg
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
