ASUS TUF RTX 2060 loud and running hot
Sxies
Hey everyone! My GPU keeps running hot and the fan is super loud when it goes over 40% (at around 60 degrees). I've tried many things such as underclocking but it didn't help me much, capping my FPS but I'm getting tired of that since I'm just losing competitive advantage, custom fan curve (everything in afterburner) & now I don't have many options left. I also can't RMA my GPU because it's been 3 months since I got my new PC & all GPUs are currently out of stock so yeah I have to struggle with this one...
1 more thing to mention is that I don't even have the OC variant of this GPU.
It usually stays between 65-75 or more degrees celsius (rainbow six siege for example) and my FPS are locked @ 100 otherwise I would get 250 but 80+ degrees. By the way, I'm not even using the highest settings, I use something between medium-high.
Same with other games such as GTA 5, Rocket League.
I do wanna mention that I got a really good case (Aqirys Canopus) with 5 fans, 2 intake & 3 exhaust & pretty decent cable management.
Does anyone else have this GPU & struggling with the same issue? Have you fixed it?
Thanks in advance!
Those temps are not too bad, how is the air flow in your case?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Really decent. The hot air is quickly pulled outside and I can feel it with my hands
As someone with blower cards, I don't think 40% fan speed should not be loud, it may be audible, but not loud.
System specs below
PSU: Corsair CX650M
It starts getting loud...But when it reaches 50%+ (usually @ 70+ degrees) it's pain for my ears...even when using the headset.
Looking it up, a few people say it is a little noisy, I think it may be the frequency made by fans.
System specs below
PSU: Corsair CX650M
