RTX 3070 load...
Go to solution Solved by seban,
Just now, Dunne Djan said:
uhm only discord and nzxt cam for monitoring the gpu
Go to your discord settings and turn off "In-game overlay". See if it helps.
2 minutes ago, Dunne Djan said:
Hi
I recently played Rainbow six siege and i got 110 fps, but i saw that my gpu load was always 100% is this normal??
CPU: I7 7700K | GPU: RTX 3070 Ventus 2x 8GB | msi b250m bazooka
what apps do you have in your backround? and have you done any thing in the nvidia control panel?
hi, im renata bliss and am ur freestyle dance teacher
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486892
i did change a resolution but i dont use it and i changed my colors a bit
what resolution are you playing at
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486906
GPU usage at 100% is what you want. If it was CPU usage at 100% then you would have a problem.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486907
Can you check the power management mode in "Manage 3D Settings". It should be on "Optimal Power". Not "adaptive" nor "prefer maximum perfomance"
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486910
1920x1080
to answer your question, 100% gpu load is normal and preferred over 100% cpu load
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486914
2 minutes ago, LilPach said:
Consider yourself lucky, idk if 110 FPS is a lot in rainbow since I don’t play it, but I can’t get my 3070 to do over 50% in any title I play and I bet my frames would be way better If I could. 100% is what you want to see.
he should be getting more than 190fps according to his resolution and specs.. i dont think thats really ideal
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486931
oh now im happy, i hope that u can to the same, im just scared that if i put my gpu fans on 100% that they will damage my gpu but idk it sounds weird if its gonna damage it but should i do 100%fans? then the gpu temp is a lot lower
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486933
please read my reply for LilPach
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14486941
1 minute ago, 1ppOverheat said:
check this video out on 1:55 timestamp please.. 1080p High; above 230fps
yes i know but i dont have a ryzen plus i run the game at ultra and maybe its my ram because i have 3200mhz ram but my motherboard only goes up to 2400mhz
https://linustechtips.com/topic/1306184-rtx-3070-load/#findComment-14487006
