40 minutes ago, Radoo said:
Everything normal when downloading but when its finishen it is saved as internet explorer file type , dont know what is that but that is anyoing i cant open anything , can someone help me ?
Not sure the exact problem.  Where are you downloading it from?
Try the original perhaps.  Less likely to be loaded with malware.
right you just type Google into Microsoft explorer, click the first link from [Google] click "run" it then installs everything automatically, no need for any file types...
-Scott Manley, 2021
