Hi I just built a new PC, everything is new but the SSD with windows and half the RAM (same ram as old PC just added more). When I turn my PC I can see the FANs/MB/GPU/CPU Cooler/RAM turn on, but I dont get any signal to my monitor. Ive done a quick google search which wasn't helpful. Monitor was working earlier today and it has power too, so i dont think its that.
-I can now see on the MB that the VGA light is on and the BOOT light is on. Im using the same SSD from my last build that has windows installed on it. Coudl that be a problem?.
Any ideas on what to do would be great.
Cheers
EDIT: I also have power to my Keyboard and Headset USD is lighting up.
EDIT: MB has the BOOT light on too.
EDIT: Ive tried 2 different HDMI cables too.
https://linustechtips.com/topic/1305261-just-built-a-new-pc-need-help/
8 hours ago, camieabz said:
If the gfx card has any additional power connectors, ensure they are connected. Re-seat gfx card. Ensure monitor(s) are plugged into the gfx card and not the mobo gfx slot (s). 😉
Moniters are plugged in and I re-seated the GFX card. Still nothing
Cheers
Added info to topic.
