Audio problems while streaming.
11 minutes ago, NinJake said:Normally the audio crackling/robot noise is due to too much audio processing going on. I too have a 6700 processor and they are beginning to show their age under certain circumstances
Yeah.... I think it might be finally time for me to do a upgrade, tho this CPU has been doing great in gaming for 4years now.
13 minutes ago, NinJake said:I don't believe RTX voice is even supported by 10 series GPU. (20 series and newer should be)
It does support the 10 series however with a twist by looks of it, and its pretty shitty of NVIDIA. The problem is they actually downclock our memory by default if we use it. People has done some testing and investigating this. You can actually disable this ''default memory downclock'' for GTX cards. This is what impacts the performance of the RTX Voice Application. on the 10 Series its downclocked by 500Mhz and on 20 Series its downclocked by 200Mhz. There is no negative outcome to disable this memory downclock.
Talk about NVIDIA forcing users to buy a RTX Card to use this Software (which I understand, as this was suppose to be intended for RTX Cards only)
